binance-connector-java v1.9.0 websocket ERROR
| ERROR | OkHttp https://stream.binance.com:9443/… | c.b.c.c.utils.WebSocketConnection - [Connection 1] Failure
I’m facing this issue on v1.9.0. When I streaming on recent trades but it throws an error after ~50 minutes.
Anybody, can resolve this issue? please!
Are you able to always receive the disconnection after 50 mins?
yes! approximately 30 - 50 minutes it occurs in between timeframe
Hi @Sam_Jones, can you share a code example, please? Too see if we can reproduce on our side using same steps
public static void main(String[] args) {
        WebsocketClientImpl client = new WebsocketClientImpl();
        client.tradeStream("btcusdt", ((event) -> {
            System.out.println(event);
I’m just tried this code. It’s working fine but after 30-50 minutes it’ll throw an error
Thanks @Sam_Jones for the code sharing.
I’ve ran 3x using same code and on my side neither of the times had a connection failure (over 1 hour). So the connection you’re experiencing might be on your local end .
try this! exact copy of mine! why error occurs!
import client.WebSocketClientImpl;
import pojoClass.BookTickerProperties;
import com.fasterxml.jackson.core.JsonProcessingException;
import com.fasterxml.jackson.databind.ObjectMapper;
import com.fasterxml.jackson.databind.ObjectReader;
import sqlite.SqliteHelper;
import tools.ConsoleColors;
import tools.CoolFormatter;
import java.sql.Connection;
import java.text.SimpleDateFormat;
import java.util.Calendar;
import java.util.Date;
import java.util.concurrent.TimeUnit;
public class BookTickerStream {
    private static final ObjectMapper mapper = new ObjectMapper();
    private static final ObjectReader objectReader = mapper.readerFor(BookTickerProperties.class);
    @SuppressWarnings("SpellCheckingInspection")
    private static final String symbol = "btcusdt";
        WebSocketClientImpl client = new WebSocketClientImpl();
        bookTickerWithSqlite(client);
    private static void bookTickerWithSqlite(WebSocketClientImpl client) {
        //Sqlite Connection
        Connection connection = SqliteHelper.OpenOrCreateSqliteConnection(symbol);
        String tableName = SqliteHelper.CreateBookTickerPropertyTableIfNotExists(connection);
        System.out.println("All Tables : " + SqliteHelper.GetAllTables(connection));
        client.bookTicker(symbol, (event) -> {
            try {
                BookTickerProperties tickerProperties = objectReader.readValue(event);
                //Insert
                SqliteHelper.InsertBookTickerPropertyIntoTable(connection, tableName, tickerProperties);
            } catch (JsonProcessingException e) {
                e.printStackTrace();
                client.closeAllConnections();
                SqliteHelper.CloseSqliteConnection(connection);
package sqlite;
import java.sql.*;
import java.util.ArrayList;
import java.util.List;
public class SqliteHelper {
    public static Connection OpenOrCreateSqliteConnection(String dbName) {
        // SQLite's connection string
        String url = "jdbc:sqlite:C://sqlite/records/bookTicker/" + dbName + ".db";
        Connection connection = null;
        try {
            connection = DriverManager.getConnection(url);
            System.out.println("Sqlite connected to " + dbName.toUpperCase() + " database");
        } catch (SQLException e) {
            System.out.println("Sqlite connecting failed : " + e.getMessage());
        return connection;
    public static void CloseSqliteConnection(Connection connection) {
        try {
            connection.close();
            System.out.println("Sqlite connection closed!");
            System.out.println("Connection closing failed: " + e.getMessage());
    public static String CreateBookTickerPropertyTableIfNotExists(Connection connection) {
        String tableName = CoolFormatter.currentFormattedDateTime();
        try {
            Statement statement = connection.createStatement();
            String sql = "CREATE TABLE IF NOT EXISTS " + "'" + tableName + "'" +
                    "(\n" +
                    "\t\"updateId\"\tINTEGER NOT NULL UNIQUE,\n" +
                    "\t\"Symbol\"\tTEXT NOT NULL,\n" +
                    "\t\"bidPrice\"\tTEXT NOT NULL,\n" +
                    "\t\"bidQty\"\tTEXT NOT NULL,\n" +
                    "\t\"askPrice\"\tTEXT NOT NULL,\n" +
                    "\t\"askQty\"\tTEXT NOT NULL,\n" +
                    "\tPRIMARY KEY(\"updateId\")\n" +
            statement.execute(sql);
            statement.close();
            System.out.println("New table has been created if not exists, named as '" + tableName + "'");
            System.out.println("New table creation failed, named as '" + tableName + "' : " + e.getMessage());
        return tableName;
    public static void InsertBookTickerPropertyIntoTable(Connection connection, String tableName, BookTickerProperties response) {
        try {
            String sql = "INSERT INTO " + "'" + tableName + "'" + " VALUES(?,?,?,?,?,?)";
            PreparedStatement prepareStatement = connection.prepareStatement(sql);
            prepareStatement.setLong(1, response.getUpdateId());
            prepareStatement.setString(2, response.getSymbol());
            prepareStatement.setString(3, response.getBidPrice());
            prepareStatement.setString(4, response.getBidQty());
            prepareStatement.setString(5, response.getAskPrice());
            prepareStatement.setString(6, response.getAskQty());
            prepareStatement.executeUpdate();
            System.out.print("\rInsert operation success.." + CoolFormatter.currentFormattedDateTime() + " ");
            prepareStatement.close();
            System.out.println("Insert operation failed : " + e.getMessage());
package pojoClass;
import com.fasterxml.jackson.annotation.JsonIgnoreProperties;
import com.fasterxml.jackson.annotation.JsonProperty;
import org.apache.commons.lang3.builder.ToStringBuilder;
import org.apache.commons.lang3.builder.ToStringStyle;
@JsonIgnoreProperties(ignoreUnknown = true)
public class TradeProperties {
    @JsonProperty("e")
    private String eventType;
    @JsonProperty("E")
    private long eventTime;
    @JsonProperty("s")
    private String symbol;
    @JsonProperty("t")
    private long tradeId;
    @JsonProperty("p")
    private String price;
    @JsonProperty("q")
    private String quantity;
    @JsonProperty("b")
    private long buyerId;
    @JsonProperty("a")
    private long sellerId;
    @JsonProperty("T")
    private long timeStamp;
    @JsonProperty("m")
    private boolean isMaker; //'true' lower price 'false' higher price
    @JsonProperty("M")
    private boolean ignore;
    private String tradeTime; //extracted from timeStamp. Usage:SqliteHelper::SelectAllFromTable
    public TradeProperties() {
    public String getEventType() {
        return eventType;
    public void setEventType(String eventType) {
        this.eventType = eventType;
    public long getEventTime() {
        return eventTime;
    public void setEventTime(long eventTime) {
        this.eventTime = eventTime;
    public String getSymbol() {
        return symbol;
    public void setSymbol(String symbol) {
        this.symbol = symbol;
    public long getTradeId() {
        return tradeId;
    public void setTradeId(long tradeId) {
        this.tradeId = tradeId;
    public String getPrice() {
        return price;
    public void setPrice(String price) {
        this.price = price;
    public String getQuantity() {
        return quantity;
    public void setQuantity(String quantity) {
        this.quantity = quantity;
    public long getBuyerId() {
        return buyerId;
    public void setBuyerId(long buyerId) {
        this.buyerId = buyerId;
    public long getSellerId() {
        return sellerId;
    public void setSellerId(long sellerId) {
        this.sellerId = sellerId;
    public long getTimeStamp() {
        return timeStamp;
    public void setTimeStamp(long timeStamp) {
        this.timeStamp = timeStamp;
    public boolean isMaker() {
        return isMaker;
    public void setMaker(boolean maker) {
        isMaker = maker;
    public boolean isIgnore() {
        return ignore;
    public void setIgnore(boolean ignore) {
        this.ignore = ignore;
    public String getTradeTime() {
        return tradeTime;
    public void setTradeTime(String tradeTime) {
        this.tradeTime = tradeTime;
    @Override
    public String toString() {
        return new ToStringBuilder(this, ToStringStyle.SHORT_PREFIX_STYLE)
                .append("tradeId", tradeId)
                .append("symbol", symbol)
                .append("price", price)
                .append("quantity", quantity)
                .append("buyerId", buyerId)
                .append("sellerId", sellerId)
                .append("tradeTime", tradeTime)
                .append("isMaker", isMaker)
                .toString();
