Getting error, on Binance test API.
Symbol: BNBUSDT
Quantity: 0.331
Responce:
{“code”:-1013,“msg”:“Filter failure: LOT_SIZE”}
On testing on Quantity: 0.33
ORDER IS EXECUTED
On checking the LOT_SIZE
"filterType": "LOT_SIZE",
"minQty": "0.01000000",
"maxQty": "9000.00000000",
"stepSize": "0.01000000"
Can you please tell what error is causing the ERROR -1013, As the value 0.331 is within range?
