Binance API connection kind of not working
Hi!
it seems like CoinTracking can’t import my Binance data through the API. I created a fresh tax report API key and double-checked everything - looks good. However in the dashboard and in the list of trades/deposits/withdrawels there is no data from Binance… Surprisingly the API live check at this page works fine and shows the balance.
Is there an issue with the API import for past trades?
Thanks!
With a little research, I found the solution to the problem.
Solution: If you head to your wallet page there should be a box displaying what might be missed, while you have Binance highlighted. For example OTC trades from the OTC page and crypto to crypto conversions on the buy-sell-crypto page need to be manually added.
