Hi All,
which is the best way to place a a BUY order LIMIT without problems:
- Insufficient Balance Exception
- Order would trigger immediately Exception
I’m looking for an order that trigger if limit >= closePrice as soon as possible.
Let’s describe the following scenario, imagine that
EURUSDT=1,20 is the current price
Actually if you place an order with TAKE_PROFIT_LIMIT with
- stopPrice=1,19 every thing works fine
- stopPrice=1,21 the system return error: Order would trigger immediately Exception
I would like to understand if there is a solution to trigger the order immediately when the stopPrice became greater than the current price due the currency fluctuation.
I would avoid to write something like this:
if( limit >= close price)
BUY with MARKET
else
BUY with TAKEPROFIT
is there a way?
