What is the best package to use with next js. I have been advise to use binance/node/api instead binance/connector. Can someone advise what is best? " The @binance/connector
package was released on March 22, 2019. It is a legacy package that is no longer maintained. It was originally designed to be used with Node.js, but it is not compatible with Next.js, which is a React framework that uses server-side rendering (SSR). SSR means that the Next.js app is rendered on the server before it is sent to the client’s browser. This allows for better performance and SEO, but it also means that the @binance/connector
package cannot be used because it is not compatible with SSR.
The @binance/api
package is a newer package that is designed to be used with Next.js. It is also compatible with Node.js, so you can use it with any JavaScript project. The @binance/api
package provides a more modern and efficient way to interact with the Binance Spot API.
I recommend using the @binance/api
package instead of the @binance/connector
package. It is the best way to interact with the Binance Spot API and get the most out of your Next.js app."
