Base URL for Futures data
Hello community,
I would like to know which base URL should US citizens use to get Futures data?
I found out that if you live in the US then you should use binance.us URL. but it doesn’t work for me.
The request I am trying to send right now is following:
https://fapi.binance.com/fapi/v1/exchangeInfo
While it works on my location (which is Asia), it doesn’t work when I send this in my server that is hosted in the US. I get the following error:
Service unavailable from a restricted location according to 'b. Eligibility'
And if I send the request with binance.us:
https://fapi.binance.us/fapi/v1/exchangeInfo
Then I receive ‘Could not resolve host’ error.
Will appreciate any help!
It seems like futuresare not supported on Binance.US. Here is a list of the endpoints you can use on Binance US: Binance.US API Documentation
You can also not use Binance.com base endpoint in the US as the service can’t be reached from there.
