aws multiple instances
If each aws instance has an ip assigned to it, will each instance be subject to 1200 api limit individually??
Yes, Binance’s API rate limits are generally based on the IP address from which the requests originate. Therefore, if you have multiple AWS instances, and each instance has its own unique IP address, each one would be subject to its own set of rate limits.
