no active trading for some time (>> 1h) without any order placement/fills and thus no user data events
trades placed, fills happen
-> no user data received any more, websocket connection seems open but dead
This happens sporadically.
The disconnects from Binance (as stated in docs, may happen every 24h) are registered correctly, so our used websocket implementation should not silently drop close frames or something alike. Since we detect “real” disconnects correctly and our connection stays open for longer periods of time, our used implementation seems to answer Binance’ ping frames correctly.
To be more explicit in my question:
Is there any way to detect such a dead connection? Ping frames from my end seem to be answered correctly.
Is it recommended to always reset the listenKey (DELETE and POST) if we want to reconnect?
It seems that even invalid path/listenKey connections can be established, but won’t deliver any data whatsoever. Is there any way to detect this?
Hi. Thanks for reminding this missing post @Alex_Soare. Let me respond the question one by one.
(1) Can you try with CLI tool (e.g. websocat) to see if it also happens? If not, probably it’s the library/ programming issue. Please check the source code or find the original developers about this.
(2) It’s not necessary to DELETE the listen key if it’s not yet expired.
(3) So far there is no specific approach to detect the invalid stream name. Please crosscheck the listen key with the API response.
By pinging, did you mean the RestFul PUT listenKey endpoint, or is there a WS ping message we can send?
Why can’t I just keep POSTing to the listenKey endpoint - PUT will risk extending an already expired key but POST will not only extend but also create one if the old key expired.
After running the websocket for a few days, there often occurred silent drop where PUT returns 200 but no more WS updates were received - is there a limit on how many times I can keep a ListenKey alive
Hello @kh-dev ,
I’m just facing this issue, did you find any solution?
I’m refreshing the listen key every 30 min, but after some random time (more than 24h, last time it has been alive for 66h) my program stops receiving data from user data stream
I’m using the python-binance library
A weird thing that I’ve seen is that my program keeps refreshing the key with no errors. However, if I take that same key and try to refresh it manually I get the following error: APIError(code=-1125): This listenKey does not exist.
I don’t know why I’m not receiving this error in my program
