Hello there! I am trying to create a function to cancel automatically the TP & SL orders.
Now I only have this, you are free to help:
OPTION 1:
def check_delete():
symbol = "BTTUSDT"
position = client.futures_position_information(symbol = symbol)
orders = client.futures_get_open_orders(symbol= symbol)
for value in position:
if (float(value['entryPrice']) > 0.00001):
if (len(orders) % 2) == 0:
pass
else:
first = orders[0]
orderId = int(first["orderId"])
exchange.cancel_order(str(orderId), 'BTT/USDT')
else:
if len(orders) > 0:
for order in orders:
orderId = int(order["orderId"])
What do you think about? This function should be implemented before to create another position.
Like if you have a while and if “condition” you will open an order, this should be good for it.
OPTION 2:
def save_order():
time.sleep(15)
# Save last two orders after a position and order have been done
orders = client.futures_get_open_orders(symbol="BTTUSDT")
if len(orders) > 1:
order1 = orders[-1]
order1_id = order1["orderId"]
order2 = orders[-2]
order2_id = order2["orderId"]
myData = [order1_id, order2_id]
myFile = open('orders.csv', 'a+')
writer = csv.writer(myFile)
writer.writerow(myData)
myFile.close()
else:
print("No DATA to save")
def check_delete():
orders_oppened = []
# Check orders
if not orders:
df = pd.read_csv('orders.csv')
if df.empty == True:
pass
else:
for index, row in df.iterrows():
order1 = int(row["order1_id"])
order2 = int(row["order2_id"])
# Delete the column that has that value
df = df[df.order2_id != order2]
df = df.head()
df.to_csv('orders.csv', index=False, encoding='utf-8')
else:
# add orders into a list
else:
orders_oppened.append(orderId)
for index ,row in df.iterrows():
# print(order1)
# print(order2)
if (order1 in orders_oppened) and (order2 in orders_oppened):
#print("Están")
pass
if (order1 not in orders_oppened) and (order2 in orders_oppened):
# Cancel orders
if int(order["orderId"]) == order2:
exchange.cancel_order(str(order2), 'BTT/USDT')
#Delete orders based in a value
df = df.head()
if (order2 not in orders_oppened) and (order1 in orders_oppened):
#Cancel order
if int(order["orderId"]) == order1:
exchange.cancel_order(str(order1), 'BTT/USDT')
# Delete column
df = df[df.order1_id != order1]
df = df.head()
With that option you should add the function save_order()
after a position and order have been created. And then, during your code you will be free to execute check_delete()
What do you think is better or what can you change of it?
