I would like to match the asset symbols among the responses (SPOT only and rest).
Does the “coin” field in the “getall” response equal with the “asset” field in other responses?
I mean when there is an “asset” field or it contains the “asset” as a postfix, do they refer to the same entity, which can be found in the list of the getall coins?
For example the “asset” fields I would like to use:
Account Information /api/v3/account “balances” item’s “asset” field
ExchangeInfo /api/v3/exchangeInfo “symbols” item’s “baseAsset”, “quoteAsset” fields
Deposit History /wapi/v3/depositHistory.html “asset”
etc.
Thanks in advance,
