I recently tried to withdraw 2 ETH from an account to another exchange.
However, even if the request worked as it returned a response with a withdrawal id. I received an email with the following content:
Withdrawal Failed
Your account may be at risk. In order to protect your assets, withdrawals have been temporarily suspended for your account(s). Please click the button below to submit a withdrawal appeal to remove the withdrawal ban on your account(s).
I precise that the API keys I’m using have the withdrawal permission and the IP I’m launching the script from is whitelisted.
So I have two questions regarding this situation.
1 - Why this withdrawal is considered at risk since it’s beeing done form a whitelisted IP ?
2 - Is there a way to check the withdrawal status using API ? Since nothing else than the withdrawal id is beeing returned in the response.
Thanks for your support.
