I have a doubt on binance statement and also on binance API, I made some AXS staking (as you can see on print below) with quantity of 2.
Then later I did the redemption and received 2,01232876 (that means I have a reward of 0,01232876), but this rewards is appended to the redemption value and not in other record with the type “Simple Earn Flexible Interest”, I cannot get this value without knowing what staking refers to. Through the API I still not getting this value and worst, it seems like a locked staking but the statement doesn’t refer this (check the print bellow of the raw data from API).
My main question is: how to deal with this cases (when you receive the interest together with the value of the redemption?
Any help?
Best Regards,
João de Deus
