API | Spot | MyTrades endpoint is not working properly
Hello
The /api/v3/myTrades endpoint is not functioning properly. It was working last months (I have records stored on database), but today I am currently unable to retrieve the same data (using the same parameters in the request).
Could you please assist in resolving this issue? Has there been an update? Anyone with the same problem?
Could you provide more details on what changed in your data and how you’re calling the endpoint?
I’m using this endpoint /api/v3/myTrades?limit=1000&fromId=1&recvWindow=5000&symbol=MATICBUSD&timestamp=1731490146759&signature=d30c3bf3ba2988d8dcf284cf4c8492f2d2b8ff5c10b903e43aa0ee40a696de4a
At today I’m not getting any data but I get records from two months ago, as you can see the in the print bellow
It’s very strange :frowning:
Hello, can anyone help me on this?
I have the same issue. A few days ago I was still able to query my trades from 2021 and now I can’t retrieve any trades before 2022-09-04. My code didn’t change since.
To confirm that the problem comes from the API, I used another crypto portfolio tracker and it didn’t retrieve anything before this date too, even tho before it could retrieve my trades older than that date.
There’s an issue with the API.
appreciate an update on this as recently run the standard API from within the UI and it doesnt bring back anything remotely accurate. USD -$64,000 in TXN errors over 7,000 txn over 2yrs
It’s very strange, do you have any updates from support team?
Same problem with me for myTrades, Deposit and Withdraw too
Does anyone know how to solve this?
Best Regards
There is no way to fix it by ourselves unfortunately. They have to fix it on their end.
Got the same issue and tryed some other endpoint like account allOrders or marketData HistoricalTrades and same, I got an empty array and yes like 2 month ago I was able to get this data…
Same problem here. Old trades, before 2022 are not showing anymore. Please fix it as soon as possible. All wallet portfolio and tax apps are crashing.
They probably deleted any data before 2022 from their database who knows :rofl:
Lack of serious from the Binance tech team tho as this issue has been reported close to a month ago and still no news or fix yet
Still no solution, the API is not bringing all the trades like in the csv file. API is not that good at all, now become worst.
I’m also encountering the same issue — I can’t retrieve trades from 2021 anymore.
My code hasn’t changed, so it appears to be an API-related problem. I also tested using another portfolio tracker, and it couldn’t retrieve trades from before that date either, even though it could previously.
Has anyone found a solution or received any updates on this? Would appreciate any insights.
