Since a couple of hours, the following vars (“Data Projects Uplimit” & “Data Projects Purchased”) are not updating properly from:
https://www.binance.com/gateway-api/v1/friendly/pos/union?status=ALL&pageSize=200
Can you please update them as they were before?
Hi @cristipurdel , the shared endpoint it’s not a published one from Binance, therefore it’s not advised to use them (their fields might be subjected to change).
I do not understand your reply.
The endpoint was keeping track if a project staking was soldout on Binance, so it was specifically used for Binance.
I was using them for the last 6 months and since this morning they stopped working.
It’s not an API that’s meant for public use, therefore changes in the response can be subject to change without notice and users shouldn’t rely on them.
