Hi there,
I get this error: AuthenticationError: binance {“code”:-2015,“msg”:“Invalid API-key, IP, or permissions for action.”}
From trying to connect to my API from my local machine.
Used to work last year and now it stopped working.
Using CCXT library. For KuCoin works no problem - only Binance does not work. When using any IP it works but when using Restricted IP it does not.
Here is the code:
'import ccxt
import other libraries
Connects to Binance
exchange = ccxt.binance({
‘apiKey’: ‘XXXXXX’,
‘secret’: ‘XXXXXXX’,
‘options’: {
‘defaultType’: ‘future’,
I have tried a few options: deactivating Firewall completely, etc.
Can you give me some help?
Thanks,
Ciprian
