API connected TRADES received NOTHING in web order history [TESTNET]
So here is the problem I am facing.
Using python binance-futures-connector I am trying to integrate my custom trading bot into binance.
Currently as I will be testing it first, I am connecting to testnet.binancefuture.com
While testing i managed to post orders, but never seen ANYTHING on the web view in testnet.binancefuture.com:
Notice order history is empty in the screenshot
Notice the order history from my code below:
cm_futures_client = CMFutures(key='***', secret='***', base_url='https://testnet.binancefuture.com')
{'serverTime': 1736982936367}
{'feeTier': 0, 'canTrade': True, 'canDeposit': True, 'canWithdraw': True, 'updateTime': 0, 'assets': [{'asset': 'CHZ', 'walletBalance': '0.00000000', 'unrealizedProfit': '0.00000000', 'marginBalance': '0.00000000', 'maintMargin': '0.00000000', 'initialMargin': '0.00000000', 'positionInitialMargin': '0.00000000', 'openOrderInitialMargin': '0.00000000', 'maxWithdrawAmount': '0.00000000', 'crossWalletBalance': '0.00000000', 'crossUnPnl': '0.00000000', 'availableBalance': '0.00000000', 'updateTime': 0}, {'asset': 'CRV', 'walletBalance': '0.00000000', 'unrealizedProfit': '0.00000000', 'marginBalance': '0.00000000', 'maintMargin': '0.00000000', 'initialMargin': '0.00000000', 'positionInitialMargin': '0.00000000', 'openOrderInitialMargin': '0.00000000', 'maxWithdrawAmount': '0.00000000', 'crossWalletBalance': '0.00000000', 'crossUnPnl': '0.00000000', 'availableBalance': '0.00000000', 'updateTime': 0}, {'asset': 'BTC', 'walletBalance': '10.00000000', 'unrealizedProfit': '0.00000000', 'marginBalance': '10.00000000', 'maintMargin': '0.00000000', 'initialMargin': '0.00000000', 'positionInitialMargin': '0.00000000', 'openOrderInitialMargin': '0.00000000', 'maxWithdrawAmount': '10.00000000', 'crossWalletBalance': '10.00000000', 'crossUnPnl': '0.00000000', 'availableBalance': '10.00000000', 'updateTime': 1732323557386}, ... , {'symbol': 'LTCUSD_250328', 'initialMargin': '0', 'maintMargin': '0', 'unrealizedProfit': '0.00000000', 'positionInitialMargin': '0', 'openOrderInitialMargin': '0', 'leverage': '20', 'isolated': False, 'positionSide': 'BOTH', 'entryPrice': '0.00000000', 'maxQty': '5000', 'notionalValue': '0', 'isolatedWallet': '0', 'updateTime': 0, 'positionAmt': '0', 'breakEvenPrice': '0.00000000'}]}
DOTUSD_250328
WIFUSD_PERP
CHZUSD_PERP
LINKUSD_PERP
ALGOUSD_PERP
LTCUSD_250328
[{'orderId': 604675492, 'symbol': 'BTCUSD_PERP', 'pair': 'BTCUSD', 'status': 'CANCELED', 'clientOrderId': 'Ns6cTnQCoohbEr8bmesmwv', 'price': '96760', 'avgPrice': '0.0', 'origQty': '2', 'executedQty': '0', 'cumBase': '0', 'timeInForce': 'GTC', 'type': 'LIMIT', 'reduceOnly': False, 'closePosition': False, 'side': 'SELL', 'positionSide': 'BOTH', 'stopPrice': '0', 'workingType': 'CONTRACT_PRICE', 'priceProtect': False, 'priceMatch': 'NONE', 'selfTradePreventionMode': 'NONE', 'origType': 'LIMIT', 'time': 1736899528274, 'updateTime': 1736900713947}, {'orderId': 604675503, 'symbol': 'BTCUSD_PERP', 'pair': 'BTCUSD', 'status': 'CANCELED', 'clientOrderId': 'nWJ2V94ooaXLXvuKeWZQ0N', 'price': '96760', 'avgPrice': '0.0', 'origQty': '2', 'executedQty': '0', 'cumBase': '0', 'timeInForce': 'GTC', 'type': 'LIMIT', 'reduceOnly': False, 'closePosition': False, 'side': 'SELL', 'positionSide': 'BOTH', 'stopPrice': '0', 'workingType': 'CONTRACT_PRICE', 'priceProtect': False, 'priceMatch': 'NONE', 'selfTradePreventionMode': 'NONE', 'origType': 'LIMIT', 'time': 1736899589959, 'updateTime': 1736900713947}]
Found error. status: 400, error code: -2011, error message: Unknown order sent.
{'code': 200, 'msg': 'The operation of cancel all open order is done.'}
END ORDERS
  File "C:\Users\...\Desktop\flash\coingate\biance-connect.py", line 73, in <module>
    response = cm_futures_client.new_order(**params)
  File "C:\Users\...\Desktop\flash\coingate\env\Lib\site-packages\binance\cm_futures\account.py", line 77, in new_order
    return self.sign_request("POST", url_path, params)
  File "C:\Users\...\Desktop\flash\coingate\env\Lib\site-packages\binance\api.py", line 83, in sign_request
    return self.send_request(http_method, url_path, payload, special)
  File "C:\Users\...\Desktop\flash\coingate\env\Lib\site-packages\binance\api.py", line 118, in send_request
    self._handle_exception(response)
  File "C:\Users\...\Desktop\flash\coingate\env\Lib\site-packages\binance\api.py", line 172, in _handle_exception
    raise ClientError(status_code, err["code"], err["msg"], response.headers)
binance.error.ClientError: (400, -4024, "Limit price can't be lower than 194.179", {'Content-Type': 'application/json', 'Content-Length': '62', 'Connection': 'keep-alive', 'Date': 'Wed, 15 Jan 2025 23:15:40 GMT', 'Access-Control-Allow-Methods': 'GET, POST, PUT, DELETE, OPTIONS', 'Server': 'Bengine', 'x-mbx-used-weight-1m': '-1', 'x-mbx-order-count-1m': '1', 'x-response-time': '1ms', 'Access-Control-Allow-Origin': '*', 'X-Cache': 'Error from cloudfront', 'Via': '1.1 923c2d2f00d1c4aa09564e5db1f3c7a8.cloudfront.net (CloudFront)', 'X-Amz-Cf-Pop': 'LIS50-P1', 'X-Amz-Cf-Id': 'tb7giO75H9pL1Z_Pb0cMdMrPMqWbgqH0J51lLp_Jk1NddRnst9FIIA=='})
What is really bothering me is that 1:
API key matches 100%. It works and connects.
I managed to post 2 orders yesterday, but in the webview my margin is still the initial since I opened the account - 15000$ Testnet
When I try to post another order right now, through my code, I always get “Insufficient margin” error.
THE API KEY IS THE CORRECT ONE.
I am not sure if I’m doing something wrong or binance simply does not show bot trades in the normal history… (at least on testnet?)
Somebody who’s been around and found out, please help me :slight_smile:
As the two orders have been canceled, it is normal that nothing happened.
Since you’re trying to sell BTCUSD_PERP in your order and haven’t provided the account’s balance for BTCUSD_PERP, does the account actually hold any BTCUSD_PERP?
The account has the initial usdt balance that it is given = 15 000 USDT
USDT and BTCUSD_PERP are two different things.
But whre can I see the history of orders I’ve made in the Binancefutures testnet UI?
And how am I supposed to do a (test) trade ?
I thought I was over the valley of dispair:
(going to be about a year coding these trading strategies, finally got something in late november that in another better testnet that reflects real prices better than binance, and is working nonstop with consistent profits for like over a month now)
So yeah, I know that technicalities matter, there is difference between USDT and BTCUSD_PERP but where can I access in the UI the trades I am trying to do with my bot?
Taking the opportunity, I will go straight to the point:
Is USDT to * conversion automatic? If not, my main future trading pairs are going to be BTC/USDT , SOL/USDT and ETH/USDT, which would these be in the UI and what string would correspond to them for the bot?
Here are some answers to your questions:
Regarding the last question, what do you mean by Is USDT to * conversion automatic?
This article may help explain Perpetual Futures.
Thanks for the patiance, though it was not what I was asking… let me try to word it another way:
For example, let’s say I want to post a SHORT trade on BTCUSDT on testnet - 101150.9 | BTCUSDT USDⓈ-Margined Perpetual Chart | Binance Futures
THROUGH the api.
And I want to see it both in the UI and on my terminal where the bot is running.
What should I fill in my order code?
# Post a new order
params = {
    'symbol': 'SOLUSD_250627',
    'side': 'SELL',
    'type': 'LIMIT',
    'quantity': 1,
    'price': 194.6
