amount in readeem is possible have max
Hi i look in api of binance the amount but if i want always a max of my saving i can insert max? ofcourse no i think and how can tell at the api i want a max?
which product or endpoint that you are working on?
ii look this Postman in flaxible saving readeem
Thanks for the updates.
Unfortunately “max” is not supported for limit. Please follow the document to find out the available value for this parameter.
i follow the document but not find how is possible required a max by API can you help me ?
