hi, when i amend a reduce only order, does the order change to non reduce only?
I ask becuase when I tried to amend a reduceonly=true order (with notional < min notional), it got ejected with code -5029, saying the notional is too small.
Is this expected? Thanks
Yes. These PRICE_FILTER / PERCENT_FILTER / LOT_SIZE are required in amending order request.
ok, i ask becuase in the QA envrionment, it used to be other way around (amending a reduce only order will remain reduceonly)
