Allow IP Range subnet notation in trusted IPs
I’m using Binance API from MS Azure Cloud and I need to trust the datacenter IPs.
MS Azure provides the IP subnet ranges like below:
40.79.130.128/27
40.89.131.148/32
40.89.141.103/32
It could be great if we could provide such notation instead of listing all IPs (which can be painful).
Many thanks,
Stephane
Thank you for the feedback, we’ll share internaly :slight_smile:
Any updates on this? Is this already possible? I would really need this since my ISP uses CGNAT which means I get a random IP from a range for every single request. My only option now is to disable the restriction all together which is not really desired.
How im new here can you help me?
It would be very useful to be able to specify IP ranges.
Any news on this?
Unfortunately, Binance currently doesn’t allow ranges, and the maximum number of IPs you can specify is very limited.
