Note: If both
startTime
andendTime
are sent,limit
should not be sent AND the distance betweenstartTime
andendTime
must be less than 24 hours.
If you request data for a range of dates, first the data was given for 24 hours, then for 1 hour.
Now, after updating 2022-12-05, the data is only given for 1000 trades!
This is very little, catastrophically.
Now, if I want to download data for one trading pair for 24h, I have to wait for almost a day))
And if you want to get data for several coins, or for a month?
If limit not provided, regardless of used in combination or sent individually, the endpoint will use the default limit.
https://binance-docs.github.io/apidocs/spot/en/#change-log
- Changes to
GET /api/v3/aggTrades
- New behavior:
startTime
andendTime
can be used individually and the 1 hour limit has been removed.
- If
limit
The maximum limit is 1000 trades. This is very little…
Has this problem not affected anyone yet this week?!
