ts-00
January 27, 2022, 8:34pm
1
Currently, when creating an order, the response can contain fills
, however the fills
does not contain the field tradeId
and time
within the fills:
"symbol": "BTCUSDT",
"orderId": 28,
"orderListId": -1,
"type": "MARKET",
"side": "SELL",
"fills": [
// Please add "tradeId" and "time" !
"price": "4000.00000000",
"qty": "1.00000000",
"commission": "4.00000000",
"commissionAsset": "USDT"
Please add tradeId
and time
within the fills
, to avoid the need for an additional call of GET /api/v3/myTrades
. Those two properties should be included in any responded trade-record (the orderId
can be derived by its parent-order, so there is no need to add orderId
within the fills.).
Could you kindly specify which endpoint you are using to create the order?
ts-00
January 28, 2022, 9:44am
3
@tantialex The endpoint is POST /api/v3/order
The properties tradeId
and time
are very important facts about a trade and should be always included in any responded trade-record. Please add these two properties in the order response within fills
tradeId
is included in the response, however it is missing in the documentation. This will be amended in the future.
As for trade timestamp, you can use the transactTime
property of the order.
ts-00
January 28, 2022, 10:22am
5
@tantialex Are you really sure. I am not talking about GET /api/v3/myTrades
which always includes id
I am talking about the fills
-property coming from POST /api/v3/order
. I tried it again and I see that id
is indeed null
, so I assume that it is not sent along the other trade information within fills
. Can you look at it? Maybe there is another issue.
I can confirm that $.fills[].tradeId
is available for POST https://api.binance.com/api/v3/order
Could you please provide a sample url and the response received so that we can further diagnose?
Omit sensitive data.
ts-00
January 29, 2022, 1:24am
7
tantialex:
tradeId
@tantialex is this field called id
or tradeId
? I get the following response and you can see that fills
id is set to 0 (which is wrong):
"executedQty":xxx
"fills": [
"commission":xxx
"commissionAsset": "ETH",
"id": 0,
"isBestMatch": false,
"isBuyer": false,
"isMaker": false,
"orderId": 0,
"price": xxx,
"qty": xxx,
"time": 0
"orderId": xxx,
"origQty": xxx,
"price": xxx,
"side": "BUY",
"status": "FILLED",
"symbol": "ETHUSDC",
"timeInForce": "xxx",
"transactTime": xxx,
"type": "LIMIT"
@tantialex Do you mean $.fills[].tradeId
or $.fills[].id
$.fills[].tradeId
Could you please define the url used to obtain the response above, and the library you are using to connect to the API?
ts-00
January 29, 2022, 10:31am
9
I use java “xchange binance api” and “binance java api”. But both, defines id
instead of tradeId
and requests id
instead of tradeId
@tantialex Can you please submit a response from your own so I can see the right responded property names (e.g. tradeId
instead of id
"symbol": "BNBUSDT",
"orderId": 3621851162,
"orderListId": -1,
"clientOrderId": "XfHajRhw8MDtdafi1X8jxi",
"transactTime": 1643363776896,
"price": "0.00000000",
"origQty": "0.10000000",
"executedQty": "0.10000000",
"cummulativeQuoteQty": "38.45000000",
"status": "FILLED",
"timeInForce": "GTC",
"type": "MARKET",
"side": "SELL",
"fills": [
"price": "384.50000000",
"qty": "0.10000000",
"commission": "0.00007501",
"commissionAsset": "BNB",
"tradeId": 510209803
The above is the schema of the /api/v3/order response. Your issue seems to be with the third-party library, I suggest contacting the owner to better diagnose the issue.
ts-00
January 29, 2022, 10:40am
11
@tantialex Is there any documentation where I find the whole json responses for /api/v3/
? The binance-spot-api-docs/rest-api.md at master · binance/binance-spot-api-docs · GitHub does not show all json responded properties…
The below is correct, with an amendment to come for the tradeId.
<!-- START doctoc generated TOC please keep comment here to allow auto update -->
<!-- DON'T EDIT THIS SECTION, INSTEAD RE-RUN doctoc TO UPDATE -->
**Table of Contents** *generated with [DocToc](https://github.com/thlorenz/doctoc)*
- [General API Information](#general-api-information)
- [HTTP Return Codes](#http-return-codes)
- [Error Codes](#error-codes)
- [General Information on Endpoints](#general-information-on-endpoints)
- [LIMITS](#limits)
- [General Info on Limits](#general-info-on-limits)
- [IP Limits](#ip-limits)
- [Order Rate Limits](#order-rate-limits)
- [Data Sources](#data-sources)
- [Endpoint security type](#endpoint-security-type)
- [SIGNED (TRADE and USER_DATA) Endpoint security](#signed-trade-and-user_data-endpoint-security)
- [Timing security](#timing-security)
- [SIGNED Endpoint Examples for POST /api/v3/order](#signed-endpoint-examples-for-post-apiv3order)
- [Example 1: As a request body](#example-1-as-a-request-body)
- [Example 2: As a query string](#example-2-as-a-query-string)
- [Example 3: Mixed query string and request body](#example-3-mixed-query-string-and-request-body)
This file has been truncated. show original
ts-00
January 29, 2022, 10:47am
13
tantialex:
tradeId
Ok, thanks. One minor note: As most 3rd party libs use the same response type for order.fills
and /api/v3/myTrades
, it would be reasonable to rename tradeId
to id
because /api/v3/myTrades
calls it also id
and not tradeId
"symbol": "BNBBTC",
// api/v3/myTrades uses "id" and not "tradeId"
"id": 28457,
"orderId": 100234,
"orderListId": -1,
"price": "4.00000100",
"qty": "12.00000000",
"quoteQty": "48.000012",
"commission": "10.10000000",
"time": 1499865549590,
"isBuyer": true,
"isMaker": false,
"isBestMatch": true
While this is a bad assumption which should not be made by third-parties, we will consider it in a future iteration. Thanks for bringing it to our attention.
